Panny PW6
Discussion in 'Plasma TVs Forum' started by cwoj, Oct 15, 2004.
  1. cwoj
    cwoj
    I know that this is a display, however what options do you have to attaching some basic speakers to it, without using an amp?
    cheers
    cwoj
  2. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    The screen does have the ability to connect seperate speakers to it without the use of an amp, althouh most go for an all in one 5.1 system or the use of an amp and seperates.
    Quattro
  3. cwoj
    cwoj
    do these speakers need to be active ones or is there a small degree of amplification from the display?
  4. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    You simply connect the speakers using the spring clips as you do with any kit, volume control on the remote for the volume and away you go. You would need a scart board though to send the sound to the screen from you source i believe. You can buy dedicated speakers for the screen but not many do and at over £200 not a good buy when you can buy better for cheaper.
    Quattro
  5. rafaqat
    rafaqat
    Sep 28, 2004
    82
    What is the PW6 like with upscaling and downscaling of things like VHS and Sky/NTL?
    I notice that some other plasmas in the 2K range specify things like DCDi Farouda to help with scaling. What's the PW6 like in comparison to plasmas with DCDi?
  6. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,516
    Kent
    +830
    It's not just the DCDi bit, but that does go a long way. DCDi is a technique for deinterlacing (turning into progressive scan) but doesn't have anything to do with scaling. For instance the Fujitsu VHA30 uses DCDi for deinterlacing (among other technologies) which IMO puts it above the Panasonic by a noticeable amount. However something like the Samsung screens which incorporate DCDi (again among other things) are not so hot. As a bargain plasma it's great but factors like the quality of analogue to digital conversion, internal circuitry etc get in the way. And as with any technology you could have all the big name parts (eg. Panasonic glass, pixelworks scaling, silicon image deinterlacing, Burr Brown DACS, 12-bit video converters) and it still be put together badly!!!!!
    BTW VHS always looks horrible on plasmas!!!
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Most of the video boards include an audio in for use with built in speakers. and ~RS sell some generic pasma speakers for £99
  8. rafaqat
    rafaqat
    Sep 28, 2004
    82
    Ok, so I can pretty much safely buy a PW6 in the knowledge that it has pretty decent scaling and de-interlacing hardware and that something like the Samsung 42D4 or the LG 42x11 type plasmas aren't going to outperform it in the scaling/de-interlacing stakes?
    I think my biggest worry is if the wife ever turns round and says she's not impressed by the picture. :)
  9. stephinson
    stephinson
    Sep 28, 2004
    55
    She Will NOT :thumbsup:
  10. cwoj
    cwoj
    is there anything you can do about this? the schools thats buying this have a lot of content of vhs tapes?
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    except for getting a Hi quality VCR not much, a top end S-VHS deck may help..... Top Panny or JVC unit approx £200
  12. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Liam is a purist, as most folks here are. The dear little kiddies won't have their noses pressed against the glass, it'll be OK for them,just get them gradually weaned off VHS and on to DVD, they're easy to record/author now. You will improve the quality of recording and pre recorded VHS by getting an S-VHS player. They are cheap as chips now, you can get a JVC one for £89 all over the internet. The scart input on the screen can take standard VHS or s-video, or RGB from a set top box, so no problems, it should go together fine. The built in amp will make enough noise as long as the little blighters can shut up when asked, it's not exactly hi fi, but it'll do the job.
  13. cwoj
    cwoj
    maw, thats perfect news. thanks for the reply
