Panny PW6 Scart Connection
Discussion in 'Cables & Switches' started by Bobby_Dazzler, Aug 16, 2004.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi all
    I am about to buy a Pannny PW6 complete with the scart imput board.... My question is, if I purchase a Scart box as on JS Technologys web site and connect my sony dav and Sky + to the scart box with my PS2 connected via the Imputs on the dav (red white and Yellow)can any one see any pitfalls of this whole set up?
    Regards
    Bobby :clap:
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,409
    The Borders
    +3,228
    Hello Bobby
    The excitements getting to you then :)
    01. JS Technology Converters - John's converters are for use where no SCART input is available or its preferable to not use SCART inputs with a particular TV or Display.
    02. Panasonic SCART terminal Board - of all the options available the SCART Input board on the 6 Series Displays has proven to be the least satisfactory; often giving (for me) a way too soft image (though others disagree).
    03. Signal type - your Digibox, DVD and PS2 all have various Output options that can be selected to get best picture quality into your Display.
    SKY+ - has S-Video and Composite or RGB via SCART.
    PS2 - has Composite (yellow RCA connector) as standard; though a low cost RGB SCART cable can be purchased.
    DVD - depending on which model you have you may have Composite, S-Video, RGB or YUV outputs.
    If the PS2 is only used once in a while then fair enough go Composite via the DVD system and from there SCART to SCART to the Display and the SKY+ via a JS Technology RGB2VGA connector into the HD15 Input on the Display.
    Otherwise which DAV do you have? Do you need the HD15 Input on the Display for a PC? and will you purchase the PS2 RGB cable kit (£15 approx).
    Best regards
    Joe
  3. Bobby_Dazzler
    Bobby_Dazzler
    hello again
    Either my lap top is up the wall or the site doesnt work when i want it too!
    anyway
    It has been suggested to me to cable my pw6 with RG59 and terminate the ends with BNC and then convert them to phono this seems a good idea to me as this setup will be wall mounted.
    so i think the set up will be sky + to PW6 via as above. sound from sky to DAV
    PS2 to dav via composite
    Dav to PW6 via RG59 bnc - phono
    is that possible?
    or what about sending the sky via the dav? then i would only need one cable going to my PW6 ! hmmm decisions decisions !
