Panny PW6 & Quintro help
Discussion in 'Plasma TVs' started by baldie, Nov 24, 2004.
  1. baldie
    baldie
    Jun 29, 2004
    52
    Evening,
    I have a PW6 and recently purchased a Quintro Scart controller and JS VGA to RGB converter, works a treat for Sky+, much better picture. However, I am unable to use the DVD player, I get no picture at all just a flicker of blue when I switch the channels on the Quintro. I have it all connected as follows:
    Sky + Scart (TV out) into Quintro scart 2
    DVD (AV Scart) into Quintro Scart 3
    Quinto TV out Scart into VGA converter
    Anyone any ideas/experience of whats happening, my DVD only has the one Scart which says AV.
  2. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    I had this problem when i connected mine up to the JS box, Your basically using the wrong connections on the Quintro, I had lost my manual so called AV sales who steered me in the right direction, so have a read of ur manual i think i use the 2 & 3 inputs furthest from the TV out connection, the one next to the TV one is for Video in/out if i recall.
    Quattro
  3. baldie
    baldie
    Jun 29, 2004
    52
    Thanks, according to the manual the Scarts are:
    2) Input RGB/S Video for Sat
    3) Input RGB/S Video for DVD
    4) Input and Output RGB S-Video for VCR
    1) Input and Output RGB/S-Video for VCR
    TV Output RGB/S video
    So I plugged the Sky box into 2 (works fine) and DVD into 3. Both of these are furthest away from the TV output scart. I have tried the DVD scart into all sockets but just cannot get a signal.
  4. baldie
    baldie
    Jun 29, 2004
    52
    I'm sure its nothing to do with this but could it be because the DVD only has 1 Scart (AV), does this need to go via the Sky + box?? Please help!
  5. mikatt
    mikatt
    Dec 22, 2003
    176
    Hampshire UK
    +6
    Baldie try either 1 or 4 I.m using both with my Panasonic DVD recorder and it works fine
    Checked the Quintro manual and I would say use scart 4 socket as thats RGB input
    Mike
  6. baldie
    baldie
    Jun 29, 2004
    52
    Thanks Mike, it was getting late last night but pretty sure I tried every connection possible. I'll give it another go this evening. In theory though, forgetting the sky connection, the Quintro TV Out scart goes into the JS VGA converter and then the DVD scart goes from the DVD into one of the scarts on the Quintro 1-4, surely it can't fail??
  7. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    input 1 on the Quintro does not switch RGB, it's composite only
    sounds like your problem is no RGB out of the dvd player
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    just checking but do both DVD scarts support RGB output? are they set to RGB output?
  9. baldie
    baldie
    Jun 29, 2004
    52
    I reckon that no RGB scart on the DVD could be the answer, not got a clue if it supports it or not though. Will have to dig out the manual. If it doesn't then where do I go, am a bit annoyed at my own stupidity for paying out for a Quintro and js vga converter and then finding that it doesn't work. Is there such a thing as a simple adaptor that I can plug into the DVD that will then convert it to RGB?
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    no but for £50 you can buy a DVD that does support RGB and £200 gets a DVD recorder with RGB inputs and outputs.......
  11. baldie
    baldie
    Jun 29, 2004
    52
    Ah, but I went down the route of buying an all in 1 Home Cinema player...! :thumbsdow
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    that was a mistake my friend......as long as it has a digital input you can do as above
  13. baldie
    baldie
    Jun 29, 2004
    52
    Thanks for the advice guys, read the DVD manual and found that you can change the scart setting to output RGB, works a treat now.
