Panny pw537 & telewest Digital
Discussion in 'Cable TV & Virgin Media TV' started by john R1, Oct 12, 2003.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Have notiched some artefacts when fast moving images are coming towards the camera did not notice this on anologue signals, is this just a problem with plasmas or is it the signal from telewest am using rgb scart via panny tuner any ideas, have not noticed any problems with dvd e.t.c.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The panny tuner is probably the culprit, also, alarmingly, try turning off RGB, the processor doesn't seem able to cope with it and sometimes does a better job on composite. Yes I know it sounds mad. I have tried it, with mixed results. I think it says something about it in the tuner handbook. If you won't miss analogue, I'd junk the tuner, your picture will be better.
