Panny PV500 Installation ..Help
Discussion in 'Plasma TVs Forum' started by sodgob, Jun 13, 2005.
  1. sodgob
    sodgob
    I am about to purchase a 37PV500 & whilst i am no idiot , am no expert at setting up TV's . do i buy through the internet & install myself or pay full price from a local dealer & have them install ? basically i would like to know if it is complicated to set up correctly ... many thanks guys.
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    What have you got to set up?
    How are you mounting it?
    What conections are you using?
    It's easy to do yourself...that's what these forums are for.
  3. sodgob
    sodgob
    thanks Mal , scuse my ignorance this is my first time on here , i have a DVD player , video recorder & NTL box . it will be the cab model so no problem there. was just confused after reading about gold leads Etc & wondered if it will come with enough leads .
    many thanks .
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    It won't come with any leads, are you using SCARTS?
    Does your DVD player have component out on the back?
  5. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    had mine up and running in about 15 minutes, set up the pedestal, asked the missus to help mount the tv on the pedestal, fastened a few screws and voila!!
    for optimum picture quality, quality cables are a must.
  6. lasitha
    lasitha
    Jan 26, 2004
    270
    London
    +3
    If you are buying it from John Lewis, they will install it for £35.
  7. Stokesey
    Stokesey
    That's a discrace, spend £2.5k and they still want to charge you £35 to install they are having a laugh!!
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,827
    Galactica C.I.C.
    +272
    INstall it your self buy following easy instructions in the manual.
    Any problems and we are here to help :thumbsup:
  9. sodgob
    sodgob
    Thanks for all you comments guys ..good to know you are around...one final question ... i read you need ''good'' leads & they make all the difference.. any suggestions .. type / supplier ? many thanks
  10. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    what leads do you need.
