Panny PV500 and SKY
Discussion in 'Plasma TVs' started by gatekeeper1999, Aug 6, 2005.
  1. gatekeeper1999
    gatekeeper1999
    Just got a PV500 and Sky Digital (Thomson box, not SKY+). Pretty impressed but not by the picture quality through sky. Changed sky to RGB and slight improvement. But watching the cricket on Ch4 thru' sky and the picture is pretty poor. There is a fuzziness around the players and the ball, especially when the camera is far away from the action.
    Am using the cheapo scart lead which came with the sky to connect to AV1. Would a more expensive scart help?? There seems to be a difference of opinions on this on these forums. Any help much appreciated.
    Gatey
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    13,993
    2
    4
    137
    Garstang, Lancs
    +1,571
    A better lead should help a bit...try TV cables.
    If it says AV1/RGB when you go on to the sky channel then that is the best picture quality and a better cable is your next option.
    Also make sure you are on Normal and not Dynamic.
  3. crank
    crank
    Also remember it takes around 200hrs for your plasma to bed in,after which there will be an increase in picture quality.Please remember to turn your contrast and brightness down to 50% at the most or it could end in"TEARS!" :eek:
  4. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    Also, Channel 4 have really squeezed the bitrate on their test coverage - I certainly noticed that the quality wasn't as good as other sports channels. Maybe a Lumagen scaler could eek a fraction more out of such a dodgy signal...
    ... but on the bright side, it looks like we're going to whup their Ozzie bottoms!*
    * I mean, they can't possibly score 107 with only their tail-enders, could they? Could they...?
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Oh please stop being so melodromatic. Posts like this only increase paranoia among plasma users. I didn't do this with my plasma, and I had no problems at all.
  6. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    Hey, Nick UK - that seems a bit harsh. I'd take issue with the idea that 'running it in' will increase the picture quality - though many say that plasma PQ does improve marginally over time. However, reduced contrast and brightness for the first 200 hours is pretty standard advice (less paranoid that Panasonic's 1000 hours!). The most critical, surely, is to get it off Dynamic mode to Cinema or Normal. And remember that each input has its own settings.
    I think it's irresponsible to say to people that they don't need to do any of this, especially on a forum where people come for advice because they're new to plasmas. Just because you didn't have any problems doesn't mean that someone who's left it on Dynamic with the contrast turned up won't.
  7. -Jay-
    -Jay-
    Jul 26, 2002
    4,882
    Kop End
    +135
    The cricket looks very good on my PW6 using a JS VGA to RGB box, I hate cricket but i love to see us beat them at anything :D
    A better scart will help no end as someone has already said, doe's the JS box work on the pv500? if so i'd look at buying one as it really doe's make sky look ace.
  8. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    Thanks, Jay - I am using a very thin and cheap scart, but haven't bothered upgrading it as the PQ on almost all the SKY channels is so good! I'll give a better one a try, and see if it adds anything. I'm not sure that a VGA > RGB box would be appropriate - it's going into an RGB input anyway... (I may be wrong on this!)
  9. Goooner
    Goooner
    Jul 23, 2005
    31,067
    2
    Milton Keynes
    +10,076
    Can't say I've noticed any problems with the cricket or football for that matter on my PV500, either from Sky or Freeview, both look really good.
    They very nearly did though didn't they :rolleyes:
  10. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    2 runs... eeek!
  11. Lionheart
    Lionheart
    I see people saying dont run your panny in dynamic mode but no one says what will happen if u did...loads of people must have left their settings more or less as is out of the box....if dynamic was such a bad setting i cant see Panasonic providing it in the first place, or at the very least have a warning about not using it when you first use the tv for how many run in hours...maybe they should put a big red button on the tv for dynamic mode with the words Dont press written on it lol
  12. Lionheart
    Lionheart
    Just had a look at the pv500 FAQs and it says Dynmaic mode reduces the life of the screen...fair enough ....use dynamic sparingly then if u like it in that mode
  13. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    Yup - it's basically the default setting because it makes the screens look best in the bright lights of a TV showroom. It says a lot about what manufacturers think of TV salesmen that they assume they won't even be able to adjust the mode before displaying the set, so it's the rest of us that have to do it... :)
  14. Korum
    Korum
    Feb 19, 2005
    4,227
    Stockton-on-Tees
    +666
    I'm on the other end of the scale gatekeeper, I was sittiing watching the cricket thinking how great it looked on my PV500.I've got Sky+ and use a Maplins Nikkei scart lead and I've been very impressed with the PQ on almost every sky channel.
  15. Sluggster
    Sluggster
    Nov 30, 2004
    524
    28
    Fareham, Hampshire
    +31
    Just a thought. My Sky box came set up with a normal rf signal output and I had to go in to the Sky box set up screen to choose an RGB output. Just having a SCART cable does not mean your Sky box is actually outputting RGB. I wonder how many people are running rf through the SCART and not RGB? The PQ is very much higher once RGB is set as the output signal.
    I have countless friends who are not aware of this.
    Regards,
    Slugg
  16. TommyB
    TommyB
    a slightly off topic question.. but what does it mean when you 'change Sky to RGB ' ?
  17. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,597
    Galactica C.I.C.
    +199
    Right,
    Dynamic mode is the default mode of the plasma. Its there to make it stand out in the crowd when on display in a brightley lit showroom. Dynamic mode has the contrast set to 100%. Not only does this crush the white detail, but it also reduces the plasmas life span. A plasma is a decaying device and keeping it in dynamic mode makes the plasma work harder than it needs to. Its not exacly a great picture in this mode either. I would personaly use Cinema or normal modes for tv and movie watching. :)
    Dave.
  18. gatekeeper1999
    gatekeeper1999
    Thank you all. Have changed from dynamic to normal and reduced contrast/brightness to 50%. Cant really tell if any improvements because WE BEAT THEM IN UNDER FOUR DAYS!
    Will also invest in a better scart probably the THOR:
    http://www.tvcables.co.uk/cgi-bin/tvcables/FORUM-SP1.html
    Bring on HD.
  19. Lionheart
    Lionheart
    I agree Dave....the normal and cinema mode certainly give a much more realistic picture....when I first got my pv500 I did'nt know about how to set up a plasma and Im eternally greatful for this forum and the great advice contained herein
  20. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    if you go to settings in your sky menu you can set the output to rgb then you can set your panel input to rgb and this helps to improve the pq :smashin:
  21. loz
    loz
    Jun 4, 2001
    13,058
    +1,796
    None.
    Scart doesn't carry RF.
    What you mean is composite. The Scart lead carries a composite signal as well as RGB. And if RGB isn't enabled on the Sky box, anyone connecting via Sky will see a poorer (but better than RF) composite signal rather than RGB.
