Panny Progressive Scan
Discussion in 'Plasma TVs' started by Claus, Jan 29, 2003.
  1. Claus
    Claus
    Hi!
    Do you know if the Panasonic PW5 can turn PAL signals into
    progressive PAL pictures.
    Thanks,
    Claus
  2. jmack
    jmack
    not sure about your question , but if you put a pal progressive signal into the panny it will show it and do a very nice job at showing it ,
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,981
    +2,785
    The plasma converts everything to progressive scan. It cannot display an interlaced image. The real questions are
    Can it accept a progressive scan input?
    Is it's de-interlacing as good as that from an external device such as a prog scan dvdplayer/de-interlacer/scaler?
    The latter question must be answered by viewing.
    Gordon
    P.S The D5 cann accept PalProg from external devices and most of them will be superior to its own internal processing
  4. Claus
    Claus
    Thanks!!
    I have a Primare V10 DVD player which I can change into the V25, which is the top model. The V25 has Progressive NTSC and PAL output. It will cost me 350 pounds more. Is it worth it?
    I have an analogue satellite signal going into my S-Video VCR. Is it much better to run a S-video signal to the plasma versus a composite video signal?
    The analogue signal is crap!!
    Looking forward to your opinions!
    Regards,
    Claus
