Panny Plasma Trouble
Discussion in 'Plasma TVs Forum' started by psi3, Mar 15, 2002.
  1. psi3
    psi3
    Mar 9, 2002
    17
    3
    Gloucester
    I have a Panasonic TH-42PWD4, has anybody else had problems switching on from standby? If in standby ie Red light on but with signal applied to PC input, the display comes out of standby for about 4 seconds, displays no picture and then goes back to standby. Anybody else seen anything similar?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,216
    The Borders
    +3,385
    muscles
    Are you activating the panel using the IR remote or the front panel buttons.
    Regards
    Joe
  3. psi3
    psi3
    Mar 9, 2002
    17
    3
    Gloucester
    Joe
    Trying to get out of standby using the remote. If i switch off and back on via front panel everything is OK.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,216
    The Borders
    +3,385
    muscles
    Stick new batteries in the remote and see if that helps.
    Joe
  5. psi3
    psi3
    Mar 9, 2002
    17
    3
    Gloucester
    Joe
    Does same with Pronto
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,216
    The Borders
    +3,385
    OK
    Disconnect PC from VGA input - any difference.
    Joe
