Panny plasma problems
Discussion in 'Plasma TVs Forum' started by lab, Apr 16, 2005.
  1. lab
    lab
    I have problems with my panny TH50PD30, it powers up for a few seconds and the fans start but then it switches itself back to standby mode almost immediately - any ideas what it could be or how to correct it ?
    Thanks, Lesley
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Faulty PSU???is it under warranty?
  3. lab
    lab
    Sadly no not under warranty anymore. I have noticed that the red standby light now flashes after it has turned itself off whereas before when in standby the light was constant. Something tells me this is going to be expensive.
    Lesley
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    A couple of hundred quid I believe. Call Barron McCann directly for a quote, though if the screen is not long out of warranty, call Panasonic and throw yourself on their mercy. It is a known fault, they ought to do something for you, and have sorted this prob out of warranty for several members, and 2 customers of mine that I know of.
  5. jwillans
    jwillans
    Lesley - This is a PSU problem and happened to me after 5 days of use! My TV is still in for repair, they are waiting for a replacement part. I think the flashing standby light is giving some kind of diagnostic information.
    James
