Panny PHD8 Input Boards
Discussion in 'LCD & LED LCD TVs Forum' started by Singexpat, Aug 30, 2005.
Tags:
  1. Singexpat
    Singexpat
    I am planning to take the plunge and buy a new Panny PHD8 as soon as they become available (I think!)! I just have a query about connection and input board variations - quite a confusing issue for the unititiated!
    I will be using the panel with a Denon 3805 receiver and Denon 3910 DVD player and a local (Singapore) digital cable set top box. My initial thoughts were to connect:
    (a) the digital set top box to the 3805, then use the 3805's "monitor out" terminal to to the Panny using a component video cable;
    (b) the Denon 3910 direct to the Panny using HDMI (and using the Denon to scale up and output the image at 720p).
    If I were to go with the above connections I assume I would need to buy two optional input boards for the PHD8: ie. component and HDMI - IS THIS CORRECT?
    I think the alternative connection possibilitities would be to:
    (a) to connect straight to the panel using component rather than HDMI; or
    (b) to the 3805 using component and then use the same "monitor out" connection as for the digital cable thus meaning only one cable to the Panny and one additional input board - less cost!)
    Does anyone have any views about what is likely to get the best results with this set-up ie. component vs HDMI, and direct to the panel vs through the receiver?
    I would appreciate your thoughts!
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Think this should be in the Plasma forum :)
    It's a little higher up on the list than this one.
  4. Singexpat
    Singexpat
    My mistake - thanks.
