Panny PHD7, ATI X300, DVI/HDMI & Overscan problems
Discussion in 'Plasma TVs Forum' started by phillvickers, Mar 11, 2005.
  1. phillvickers
    phillvickers
    I'm connecting my MCE (Artisian) to a Panny 42-PHD7 using a DVI to HDMI connector from the ATI X300. I've read that the Panny's suffer from overscan and that the DVI driver options on the X300 are limited.
    I'm losing 5%-10% (taskbar, start button halved etc.) of the desktop, I'm currently 'fiddling' with Powerstrip but to no avail, does anyone know how to remove (or even reduce) the overscan? :lease:
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    How about stopping fiddling with powerstrip and just resizing the picture with the 'picture position/size' button? It sounds to me like you have a touch less than 5%, which this adjustment can easily take care of.
  3. phillvickers
    phillvickers
    If I had a 'picture position/size' button I would use it, but as far as I've seen there's nothing even remotely like this. I've currently got the screen underscanning (using powerstrip) which is better than nothing but it would be nice to have it full screen.
  4. Pottsy
    Pottsy
    Apr 15, 2003
    295
    Leicester
    +8
    Eh? On your remote, what button have you got below "Multi PIP" and above "PC"?
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Funny, I've got one of those buttons on my remote too. It resizes my screen to make the iscan DVI image fit.
    Any joy yet, Phil, or have they packed the wrong remote for your screen?
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,930
    The Borders
    +3,573
    Hello all
    Being an IT luddite maybe I'm being thick but is this not a PC - if yes set the graphics card to output 1024x768(60) for starters.
    You can then use a suitable DVD with Test patterns (or download some) and as suggested use the Size function on the Display to adjust the Display until you see all of the test pattern; there are even a couple of downloads to let you see when you have 1:1 pixel mapping (Horizontal and Vertical) happening.
    Best regards
    Joe
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    With a windows desktop set to XGA you barely need a test pattern. Just set a desktop picture of Cheryl Tweedy, and when the chest hair is sharp, bob's your uncle.
  8. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    :D :D :rotfl:
    Steve
  9. phillvickers
    phillvickers
    Thanks WAW :clap: , I was being a dunce. :oops: Tried to be too clever by making the PC do the scaling. 'Found' the size button and low and behold it works!! Thanks again, I'll now go and sit in the corner with my Dunce hat on. :lesson:
