Panny PE30 AV4 Component ???
Discussion in 'Plasma TVs Forum' started by Seanjackdan, Sep 1, 2004.
  1. Seanjackdan
    Seanjackdan
    I have had my PE30 for a couple of days now, and very very impressed.
    My question is I have my DMR-E75 DVD/Video Recorder connected to AV4 via Scart, and also AV4C connected via component, and set output on the DMR-E75 to "component(not RGB)", and turned progressive scan to "on" - I presume this is correct ???
    When watching a DVD though, and switch from AV4 to AV4C I don't see any difference in the PQ at all - should this make any difference - I presumed it would ???
    Sean...........................
