panny pd30 service menu questions
Discussion in 'Televisions' started by jdg, Dec 28, 2003.
  1. jdg
    jdg
    I've used the new digital video essentials.
    The problem is, that the picture is located a bit to the left when using my dvd player. I then corrected this, through the service menu, and the picture is centered.
    However, now the ordinary tv picture is located to the right!?
    I thought the service menu stored different settings for each type of input!? Am I mistaken?
    another question; whats the "normal" value for sub-bright?
  2. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    For a discussion on PD30 settings, you might want to browse through this thread as several people have posted details of settings they've changed to improve their PD30 picture. I'm pretty sure that near the newer end of the thread, someone has posted about the adjustments they made to sub-bright
  3. Linkintones
    Linkintones
    Sep 6, 2003
    58
    Sweden
    How do you adjust high/low red, green, blue?
    Which button do I have to press at the remote?
    //Daniel
  4. jdg
    jdg
    I have looked through that thread, but my questiobs have not been answered. (sub-bright at 240 is definately NOT normal)
  5. blindlemon
    blindlemon
    Jdg,
    Sub-bright, out of the box, seems to vary between about 80 and 120 (on the 5 PD30s I've checked). Some people claim that increasing it reduces black crushing - but YMMV. Personally, I originally increased it to 120 (from 90), then set it back again to 95. I feel that increasing brightness and reducing contrast is a much better alternative as, to my eyes, increasing sub-bright too much tends to make lighter colours look washed out.
    Linkintones,
    Press the yellow & blue fastext keys to alter values, green & red keys to cycle thru the options. To improve the "green edges" problem and reduce the overall green cast I increased both low and high red & blue (and also low-green, to a lesser extent) - increasing only one set can throw out the colour balance between light and dark tones.
  6. zeymatis
    zeymatis
    my sub bright was set at 124 out of the box ,, and i think i increaded it to 190 , which i think made a dramatic diff ,,
  7. jdg
    jdg
    Thx, for the answers regarding sub-bright, min was set to 125 out of the box.
    But my first question has still not been answered!?
  8. zeymatis
    zeymatis
    did u press store when u adjusted it ?.... but then again im not sure if each AV CHANNEL will set up on diff service menus , im thinking that it will be generic through out all AV s and not specific
  9. jdg
    jdg
    Yup I pressed store
  10. jdg
    jdg
    anyone?
  11. jdg
    jdg
    really no one??
