panny pa50 and pe50-difference.
Discussion in 'Plasma TVs' started by knobbs, May 9, 2005.
  1. knobbs
    knobbs
    hi whats the difference between pa50 and pe50 pannys, 1s got analogue tuner wts that mean.
    is there any difference picture wise.-cheers knobbs.
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    one has digital freeview and other normal analouge tuner. if u have sky or ntl u will not need digital tuner.
  3. bazlion
    bazlion
    Also the PA50 is a european imported model, I e.mailed Panasonic UK to check.
  4. knobbs
    knobbs
    european model ,is it not as good as the pe50 pic wise.
    anyone got 1.
    thanks for replys appreciated.
  5. knobbs
    knobbs
    hi cheapest ive found is pa50 1439.00 and pe50 1549.00 and 20 squid deliv any 1 recommend which, i have a sky box, got rid of the 42 in lg i had solarisation too bad.
