Panny or Sammy?
Discussion in 'Plasma TVs Forum' started by moops, Oct 27, 2005.
  1. moops
    moops
    Hi guys,
    Stumbled across this site whilst re-searching what plasma to buy and would like to congratulate you on a great comminity and also ask your opinions.
    My original choice was a Samsung PS42S5H as I can get a 20% discount where I work for these and would work out at about £1300.
    After reading quite a few posts though it has come apparent that this model is not quite up to scratch.
    Even though I can't get discount and that this model is not HD ready and is slightly smaller I think I am going to go for the Pansonic TH37PE for a similar price.
    Do you guys think this is a wise choice bearing in mind the Sammy is HD ready and 42"?
    Also what is thdifference between the PE30 & PE50?
    Moops
  2. Peabo
    Peabo
    if you're desperate for HD right now and can't break your budget, maybe the LG models would be better. The Panasonic will give you a much better picture than the S5H though.
  3. mal60908
    mal60908
    PE30 are the old models, the new ones have the 8th generation panel in them, but less inputs (VGA etc)
  4. moops
    moops
    Well after much deliberating I am actually goona go for the TH42P50E.
    As i'm not too fussed about HD it seems as though this is one of the best SD panels going at the mo?
  5. billym
    billym
    You won't be disappointed with the TH42PE50 - I've had mine for a few weeks now and it just keeps getting better and better. :thumbsup:
