Panny inputs
Discussion in 'Plasma TVs' started by Northmoorblue, May 24, 2004.
  1. Northmoorblue
    Northmoorblue
    May 18, 2004
    36
    I am considering buying the 42" PW6 Panasonic panny. I know there are different terminal boards that can be fitted, the Scart seeming to be the "standard". At present I need scart for sky, and also my present dvd has a scart output.
    Firstly how many scart inputs are there on the scart board? Secondly I was thinking of also having the Component video board fitted, to cover my options when I upgrade my dvd. I've been told that component gives a better quality picture. Is this true?
    Is this the best way to go, or are there other options / combinations to consider? I am of coarse looking for the options that are going to give me the best possible quality picture / sound etc.
    Northmoorblue
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    Maybe try a search as this has been covered loads...
  3. Northmoorblue
    Northmoorblue
    May 18, 2004
    36
    Thanks for the tip. Should have tried that first. New member not thinking!
