panny hs2 u99 error
Discussion in 'Blu-ray & DVD Players & Recorders' started by guinness1, Mar 12, 2006.
  1. guinness1
    guinness1
    Dec 27, 2004
    9
    hello guys,wile i was watching a dvd the picture did freeze and the u99 error appeared on the panny screen.
    now my dvd disk is stuck in and does not want eject.
    the only thing on the panny screen is the time and "dvd" "video" light on.
    nothing else is working.:mad:
    if i try to hold down for 10sec the power button ,will go off and the led will be on,but when i push back on the led will go off but nothing happen.
    any other way to reset it?????power+stop????any more???
    thank you
  2. guinness1
    guinness1
    Dec 27, 2004
    9
    no one having a solution for it??:lease:
  3. 375 driver
    375 driver
    Jan 7, 2006
    68
    +12
    Hi. Found this on another forum.
    Unplug the DMR HS2.
    Wait about ten to fifteen minutes,
    plug the unit in.
    Do not put the unit on but hit the open close button. This should open the tray while powering the unit. If this does not work, turn the unit off and try again. This may requie the unit being unplugged again. The open close button needs to be activated before the unit enters the recovery mode and locks everything up.
    Hope this helps.
  4. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    Try pressing and holding the Power and Stop buttons for 5 seconds.
  5. guinness1
    guinness1
    Dec 27, 2004
    9
    no luck guys,does no enter the recovery mode to.
    i manage to pull out the disk by opening it,and pushing down the dvd tray!
    once i plug it on again i could ear the tray moving inside and is stuck up again how it was before with the dvd in,still no control at all on any command,just the time and the "dvd" "video" led both lighting up:mad:
  6. 375 driver
    375 driver
    Jan 7, 2006
    68
    +12
    The only other thing is to leave it unplugged for 24 hours, and see if that helps.
  7. maldonian
    maldonian
    Nov 25, 2004
    919
    43
    +91
    These are for an E85, don't know if they work on an HS2:
    To eject a disc if the unit has locked up - in standby, press Power, Stop and Channel Up for 5 seconds.
    To restore all factory defaults - in standby, press Skip Reverse, Time Slip and Open/Close for 5 seconds.
