Panny Hs2 Recovery
Discussion in 'Blu-ray & DVD Players & Recorders' started by patmyhead, Dec 6, 2003.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    my panny has gone into crissy break mode a bit early, i inserted a ram disk presed record & the panny went blank then the lcd said recovery ,any ideas?
    P@T
  2. bobbles
    bobbles
    when it calms down and comes back on you will probably find you can not eject the disc
    turn it off
    then hold down eject it will come back on and eject the disc
  3. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    bobbles just tried that but it went back to recovery mode again ,it does this no matter what button i press
    P@T
  4. bobbles
    bobbles
    don't panic it will come out
    the trick I've always found is that you must turn it on by pressing eject this usually means it will eject without trying to read the disc
    unplug it and make sure you leave it for 30sec
    when you plug it back in it will go into recovery mode
    when it comes back on turn it off with the button
    then press eject
    by the way once ejected put in and play a dvd-video
    eject this and things should be back to normal
  5. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    still no joy it keeps going to recovery every time
    P@T
  6. bobbles
    bobbles
    yes it should but after a while recovery should end and the disc should pop out
    what happens when the recovery period ends?
  7. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    it goes into standby powers down
    I have now taken the top off & removed the ram disc by hand
    reconected the panny it went into recovery for a few seconds then back to normal
    tried the harddrive which worked fine ,then dvd movie which worked
    do you think it would be ok to use the ram disk again as it is almost new
    thank for your help
    P@T
    How do i adjust the RF output as it is clashing with other av gear
    need rf as it is dasy chained to home network so her indoors can watch corry upstairs in pease
  8. bobbles
    bobbles
    did it say U11 error if so the ram is prob knackered
    if not put in a -r which works then try again
    not sure about the RF I can not see why not surely the manual mentions how to do this
