Panny G10 plasma front glass/plastic
Discussion in 'Plasma TVs Forum' started by Roggster, Aug 21, 2013.
  1. Roggster
    Roggster
    Feb 17, 2009
    179
    +4
    Hi all,
    My father in law's TX-P50G10 suffered some grandchild damage to the front glass.
    It has some hairline scratches which are annoying during viewing.
    Looking at it, the front is just a clear glass or plastic sheet, rather then the PDP itself, so repair *should* be doable.....
    Anyone any experience with this or know a good place to get parts?
    Also if my theory is true is the front glass/plastic and bezel interchangeable with G15 or G20 (to make it easier to find spares...)?
    Ta,
    Nick
  2. MAX1210
    MAX1210
    Mar 9, 2009
    4,525
    3
    +1,239
    The glass has part number TKGA5520 and has a cost of £150.23 + VAT. Doubt you'd be able to order and fit it yourself though.
    It currently shows as in stock, so it should be a pretty quick job for a service centre.
