Panny EX85 - direct navigator to HDD
Discussion in 'Blu-ray & DVD Players & Recorders' started by sbar, Jan 2, 2007.
  1. sbar
    sbar
    Got the EX85 for Xmas and I am real impressed.
    But a silly question, when I click on direct navigator to look at the contents of the hard drive, I get momentary interference before the thumbnails come up. (A few squigglylines - very momentary) Just seems a tad odd. Just as if the machine is resetting before looking at the harddrive.
    Just wondered if this is normal.
    The machine works fine and i have no issues with it at all. Fab.
  2. sbar
    sbar
    I've worked this one out by looking through the forum. The recorder is resending out the auto switch to the TV to make it go to AV1, when I select direct navigator I can understand why it does this, but you would think this would be disbabled if I have selected RGB1 as opposed to RGB2.
    Still nothing to worry about.
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,136
    +7,062
    I would think this is more likely an issue of the way your TV happens to respond to the scart Pin 8 status rather than it being an issue of the EX85.
