Panny ES30 (RAM to another format?)
Discussion in 'Blu-ray & DVD Players & Recorders' started by dvdope, Mar 14, 2006.
  1. dvdope
    dvdope
    Finally bought a dvd recorder and plumped for the Panny ES30 (I know :eek: ). My only reason for purchasing this is because I’ve read that it can improve on the quality of the original vhs tape when transferring to dvd. (including older tapes with noise and jitter). I have literally hundreds of the buggers to transfer and hope it can do the job as well as the reviews state it can. Assuming the tapes get transferred successfully and I start using the panny for dubbing from tv, if I dub to RAM, can I then edit stuff I want to keep and then dub to another format i.e. –R; -RW; +R so it can be played in other dvd players ? Thanks for any help
  2. JayCee
    JayCee
    Jan 20, 2004
    23,754
    Lanarkshire
    +2,568
    I don't think you will be able to do that as it does not have a HDD.
    You can only record to DVD-RAM, DVD-R, DVD-RW...not DVD+R/RW
  3. zebs
    zebs
    Feb 28, 2006
    256
    28
    lowestoft
    +42
    http://www.btinternet.com/~james_lancaster/ramtor.HTML :thumbsup:
  4. JayCee
    JayCee
    Jan 20, 2004
    23,754
    Lanarkshire
    +2,568
  5. dvdope
    dvdope
    Thanks for the replies. The answer, looking at the link, would seem it is possible – providing I have a RAM compatible drive in my comp. At this time, I don’t but it’s an option for future consideration. Better get transferring those tapes:boring:
  6. zebs
    zebs
    Feb 28, 2006
    256
    28
    lowestoft
    +42
    As he had posted on here, naturally I assume he has a PC, therefore it is an option to be considered
  7. Searcher2
    Searcher2
    Nov 18, 2003
    1,447
    48
    Blackburn
    +92
    I have seen the guide - and not yet bought a DVD-RAM drive. The guide deals with editing menus etc. on the PC using authoring software.
    The advantage of DVD-RAM is that you can edit and add thumbnails using the recorder. I was hoping that I could just do a straight DVD Copy using Nero on my PC from DVD-RAM to DVD-R if I ever wanted a copy to play in another machine. Is this not possible? I don't fancy messing about with authoring.
