Panny Es-10 or Eh-50 ????
Discussion in 'Blu-ray & DVD Players & Recorders' started by nick270881, Jun 27, 2005.
  1. nick270881
    nick270881
    Feb 21, 2005
    1,206
    HULL.......Born & Bred!!
    +137
    I was about to go out and buy an ES-10 recorder, but just seen the EH-50 sitting next to it in the store!
    I will mainly be using the unit for playback (using a ps2 at the moment) but will occasionally be sending stuff from my sky+ box to dvd!
    Is it really worth the extra £100 or so for the hd version, or am i better just saving it and getting the ES-10?
    Any suggs appreciated!
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    The importance of having a HDD inside a DVD recorder is explained here. The question to ask yourself is: do you want to make edited recordings that play on other DVD players? (without having to use a PC to convert)
    If the answer is yes then buy the EH50. If not, and the capacity limitations of DVDRs doesn't bother you, then the ES10 is arguably the best budget unit at present.
