Panny EH50 - Adding a programme from PC
Discussion in 'Blu-ray & DVD Players & Recorders' started by joroma, Mar 23, 2006.
  1. joroma
    joroma
    Dec 6, 2005
    110
    +5
    Can anyone help with this one.
    I have got the first 5 episodes of Extras on my hardrive but forgot to record episode 6. I have now been given a copy of episode 6 as an avi file which I have on my pc. I've got a file convertor and can convert the avi file to DVD,VCD,SVCD,MPEG1 or MPEG2. I've got a CD RW on my PC but no DVD RW. I've tried converting to DVD format and copying the file to a cd but the Panny won't read it. Is there any way I can get the last episode onto my Panny hard drive so that I can then dub all 6 episodes onto a DVD?
    I can copy a file from my pc onto a 512MB SD Card.
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    Can your PC's DVD writer write to DVD-RAM discs? [Edit: Sorry just read you can not write DVDs, think you might be stuck then, although DVD writers can be had for around £30.00 now.]
    You will need to write to a DVD-RAM disc using the VR mode for the Panasonic DVD recorder to accept it, it will not work from a CD I don't think. Someone may have a better idea.
    Regards
    Phil
  3. joroma
    joroma
    Dec 6, 2005
    110
    +5
    My file convertor doesn't include VR mode or is that the same as DVD format which it will do?
    I am thinking about getting a DVD RW for the PC and would get one with the DVD RAM facility.
  4. davee b
    davee b
    Jul 19, 2001
    307
    leeds
    +15
    If you burn to cd as vcd or for better quality svcd, the panny might recognise it.
  5. joroma
    joroma
    Dec 6, 2005
    110
    +5
    Just tried playing it in VCD format on a cd and the Panny won't play it (this has happened before trying to play a photo slide show) In fact the Panny has never played a VCD CD. It recognises it as being VCD and shows that in the display but when I try and play it a menu of whats on the disk appears but nothing happens when I press play. According to the manual it should play VCDs. Any ideas???
  6. davee b
    davee b
    Jul 19, 2001
    307
    leeds
    +15
    Its probably the brand of disc that the player doesnt like. Try a different brand :)
  7. joroma
    joroma
    Dec 6, 2005
    110
    +5
    Thanks Davee. Any idea which brands of CD work well with this machine? I use Panasonic DVDs which as you would expect are absolutely fine.
