panny e85
Discussion in 'Blu-ray & DVD Players & Recorders' started by caleyman, Mar 2, 2005.
  1. caleyman
    caleyman
    hi,
    i was thinking about buying the panny e85 until i discovered the there was no dv link, can anybody advise on a similar quality, price and spec machine that has a dv link. looking to spend in the region of about £400
    cheers.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    The Panasonic E95 can be picked up for £410 - this is an E85 with iLink and PC/SD Card slots (plus a 160GB HDD). It also has JPEG compatibility.
    Another alternative is the Toshiba RDXS32 at £330.
    The Pioneer 520 is also available in that price range (£370) although it lacks the recording quality of the E85/E95 or the extensive features of the Toshiba.
  3. caleyman
    caleyman
    thanks, i'll have a look at these
  4. Mark H99
    Mark H99
    Hi, I've been looking at getting a DVD recorder for a while, out of interest (and probably a really stupid question :blush: ) but can you record off sky with these,
    Mark
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    Yes of course.
    Have a look at the 'Which DVD Recorder?' link in my signature for buying advice!
