panny e85, will not play dts, not showing up on av amp display.
Discussion in 'Blu-ray & DVD Players & Recorders' started by arcamalpha, Jun 7, 2005.
  1. arcamalpha
    arcamalpha
    Apr 14, 2003
    71
    cheshire,england
    All the connections appear to be correct, but panny does not seem to be playing dts, even on so called dts discs.
    Any thoughts?
    Regards.
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    you need a digital connection to your amp
    & an amp that can decode the DTS.
    Usually you then have to select the DTS soundtrack on the Dvd menu.
  3. kdp99
    kdp99
    Mar 29, 2001
    208
    Southampton,Hants,UK
    +23
    I found on my HS2 that by default the DTS digital output was turned off, go into the set up function and see if this is the case.
    Keith
