Panny E85 - can not get DVD-RAM out
Discussion in 'Blu-ray & DVD Players & Recorders' started by BluEvicE, Dec 22, 2004.
  1. BluEvicE
    BluEvicE
    Please help. I format DVD-RAM in computer with original Panasonic RAM diver to UDF 2.0, then put it into recorder and that was the last thing i see my Panny good working. Since that time recorder report error and reboot, do self check, error, reboot, .... I could not switch off, switch to HDD or eject. Only to pull cabel out of power point. Please help how to get DVD out of recorder. I hope it will work fine again.
    Thanx a lot.
  2. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    Hold the standby button for at least 15 secs and then try the eject.
  3. SteveDangerous
    SteveDangerous
    What make of DVD-RAM drive do you have in your PC? Using one of the recent LG drives seems to cause this problem with or without the Panasonic UDF drivers.
  4. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    I have the LG4120 - worked a treat with DVD-RAMs on my old HS2 (and also with DVD-RWs in my new Sony RXD500 and RX1000 for that matter).
  5. Maximumbaz
    Maximumbaz
    Feb 10, 2004
    Hampshire
    +8
    While the machine is switched off, press and hold the stop button and channel up button on the machine (not the remote) for about 5 seconds.
