Panny E55 for £150 Panny E85 for £377
Discussion in 'Blu-ray & DVD Players & Recorders' started by F G Evans, Oct 8, 2004.
  1. F G Evans
    F G Evans
    LX direct have these items in their sale section for the above prices if you use the following code (which can only be used by first time buyers to the site).
    XX749 simply use that code on the checkout screen.
    It is also possible to get free postage as well with a code but i do not know whether it is worth the risk using 2 codes at the same time
  2. rubberducker
    rubberducker
    Aug 10, 2004
    345
    how do you get this to work, as when you have addded your details, it asks your for credits card - but there is no box for the code?
    have you actually done this?
    could you post a link?
  3. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    Its there your just not looking :D
    [​IMG]
  4. Kasparaitis
    Kasparaitis
    thats interesting.
    might try it.
    thanks for the info.
  5. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +284
    Thanks for that FG Evans :thumbsup:
    I ordered E55 on friday and it arrived at 9:00 this morning.
    Cost a little over £152 including postage.
    John
  6. marteee
    marteee
    has the price gone up? now seems to weigh in at 180 odd after the discount? or have i ballsed something up? :)
  7. bluedoo
    bluedoo
    Dec 13, 2002
    405
    +15
    yes they have put the price before discount from £199.99 upto £239.99
    up £40 :thumbsdow
    glad i ordered mine before the price went up :thumbsup:
  8. ben223
    ben223
    I am very tempted to order thru LX but on reading the terms and conditions on their site, they say that they check the promotion code against the name of the person it is intended for.
    Have any of you others had a prob with this?
  9. bluedoo
    bluedoo
    Dec 13, 2002
    405
    +15
    got mine delivered today for the sum of £149.99 inc :thumbsup:
    used the 25% off and free delivery codes
    got it before they put the price up
    set it up tonight and will never use a video again(except to copy them to dvd)
  10. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    Price is back to £199 now so with the code works out at £152.94 del.
  11. bluedoo
    bluedoo
    Dec 13, 2002
    405
    +15
    use the free delivery code as well £149.99
  12. Stanman
    Stanman
    Feb 7, 2004
    1,545
    +154
    Back up to £239
  13. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    Its up to £290 now they musta twigged everyone was using the 25% discount :(
  14. burcac
    burcac
    My e55 arrived today, total cost £149.99 (Thanks for the tip off FG!)
  15. mentsugi
    mentsugi
    Oct 2, 2002
    390
    28
    +29
    Panasonic E55 for £179.95 at Richer Sounds now. :thumbsup:
  16. Kasparaitis
    Kasparaitis
    E85 at Richersounds is now £380
  17. wiggy
    wiggy
    May 15, 2002
    London
    Any others known?
  18. TonyIles
    TonyIles
    The Tosh Dr-1 is £199.95 at Richer Sounds, with firewire and DVD-RW capability, its £187 at Morgan Computers!!!!
  19. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,300
    +677
    XX747 gives you 20% off.
  20. AJ_78
    AJ_78
    Anyone find the Panasonic E85 for cheaper than £400 the one in Richard Sounds is region 2, and can't seem to find them anywhere, was hoping to get a JL match on this for the panny plasma deal
  21. HMHB
    HMHB
    Nov 11, 2001
    26,847
    Nottinghamshire
    +5,623
    I got the Multi region E85 from Richer Sounds for £399 here
  22. norfred
    norfred
    May 2, 2004
    289
    bromley
    +9
    If you visit richersounds web site and print out the price list they will match that price at the local branch.
    region 2=374...
    multi region =399.95
    I got mine delivered because the branch had no stock. working fine at the moment
    norfred
  23. K-BOXER2
    K-BOXER2
    hi the above dvdrecorder is £179.99 if bought online from Comets £249.99 if bought in store :clap:
  24. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    I think that price must be for the E55 not the E85.
