Panny E55 best connection
Discussion in 'Blu-ray & DVD Players & Recorders' started by wattsj, Sep 23, 2004.
  1. wattsj
    wattsj
    Panny E55 AV1 ---> Sky+ VCR scart ---> Sky+ TV scart ---> Plasma scart
    or
    Sky+ TV scart ---> Panny E55 AV1 ---> Panny E55 AV2 ---> Plasma scart
    Which would you say is the best connection.
    With the first the Sky+ does the scart switching and with the second the E55 does the switching.
    I'm a little confused as to what is the best scenario ? :confused:
    I typing this in work so apologies if the scart names are incorrect but I'm sure you'll understand what I'm saying !
  2. QED
    QED
  3. Zedmeister
    Zedmeister
    Sep 9, 2004
    60
    11
    If you connect the Sky+ TV scart to the Panny, you can set it up via RGB and get better recordings on the Panny. However, you cannot use the Ext. Link function with RGB but then again you have Sky+ so you probably don't want to use it. I don't think you will get RGB on the VCR scart.
