Panny E50 RGB/CVBS on Timer wakeup??
Discussion in 'Blu-ray & DVD Players & Recorders' started by nictry, Nov 2, 2003.
  1. nictry
    nictry
    Apr 28, 2002
    5,780
    Kent
    +645
    I am confused!!!
    I have a Panny E50 and have Sky through AV2 with RGB out from Sky and Connections set for RGB, the Scart from AV1 on the Panny goes into one of the RGB (AV2)slots on the TV.
    When I have SKY on the RGB signal shows on the TV, when I have the Panny on with Sky showing I have an RGB signal on the TV, BUT! when I use the timer mode on the Panny it switches itself on and the TV changes to BBC1???? which is strange enough but when I then use the remote to change back to AV2 (RGB input on the TV) it shows as CVBS recording from Sky?????? :mad:
    I think (although I am not certain) that the recording is being done as RGB but why would it do this???? And can this be solved :rolleyes:
    All help much appreciated:hiya:
  2. nictry
    nictry
    Apr 28, 2002
    5,780
    Kent
    +645
    Juct checking in!!! Anyone help with my question above???
    Pleeeeeease!!
