Panny E50 -R discs and archive set up ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by the.jackall, Jan 2, 2004.
  1. the.jackall
    the.jackall
    Mar 3, 2003
    29
    Northumberland
    Just bought one of these panasonic e50 recorders which im quite impressed with.
    Would I be right in thinking the best way to archive your vhs is by using scart to scart ?
    I did a test run which came out good however i was wondering if the s-video connection or the three (red,white,yellow, leads would give me better transfers.
    Whats the best discs to buy for archiving on -R ?
    Ive used the bulkpaq 4 speeds which do the job with no coasters but can i be using better ?
    Is there a disc which will give you higher performence recordings of longer than 2 hours or are they all about the same ?
  2. bobbles
    bobbles
    standard VHS can only output a composite signal so scart is your best bet. It is impossible to improve the quality of the original recording and vhs are usually quite noisy recordings so you would be better off sticking to small recording lengths
    bukpaq are notoriously unreliable but if they work for you stick with them as the discs themselves can not improve quality
    you can buy double sided ram for around £5
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    If the media work, then the quality will be nearly identical between one make and the next as the recording is digital.
    Therefore the only difference in quality is related to the time recorded on the media. Personally I wouldn't go beyond 2hrs 15 mins when recording from a digital source. For archiving vhs 4hrs would probably be ok.
    BulkpaQ are notorious for not being reliable in panasonic machines, better to use datawrite grey or yellow. Reds are ok as long as you finalise in one session without removing the media from the machine.
  4. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,253
    Bristol
    +8,571
    I wouldnt use anything that carrys the name of Datawrite or Bulkpaq, if you do you are asking for trouble, I have been burning dvdrs for a year now and those 2 brands are the worst there are, sure you will get good burns but 6+months down the line dont be suprisied if the disc doesnt read very well anymore and finally one day it will refuse to read at all, has happened to me and many other people, stick with quality media like RITEK, discs I burned last xmas are still going strong now.
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Ritek are a definate no-no for most of the panasonics as they don't seem to like the dye, and you are lucky if your machine will work with them. Datawrite have got a much better reputation for panasonics on this and other forums.
  6. krismcewan
    krismcewan
    Feb 6, 2004
    70
    11
    Edinburgh
    I have been using both bulkpaq and datawrite in my panny and they work great.
    And as a point of note the above brands use ritek dye
  7. sandy2011
    sandy2011
