Panny E50 Prog Scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by janmolby, May 19, 2004.
  1. janmolby
    janmolby
    Mar 30, 2004
    33
    I already have a Panny E50 and am looking to buy a Panny Plasma. On the Plasma forum the guys are raving about the difference Progressive scan makes to pic quality.
    Is the E50 progressive scan capable?
    If not, do you think it would be worthwhile buying a seperate player just for playback, which is prog scan capable? Will it make that much difference?
  2. cuewoz1
    cuewoz1
    Oct 30, 2003
    187
    The panny E50 isn't prog scan sorry.
    It is a better picture IMHO but not a really big difference (not with mine anyway), I think with prog scan if you can afford another player.
