Panny E30 Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by bobbles, Jan 22, 2003.
  1. bobbles
    bobbles
    Just got it today very impressive
    I have it set up in the following way
    SKY+ TV RGB OUT -> DVDR RGB IN AV2 -> DVDR RGB OUT AV1 -> RGB TV IN
    On the DVDR I have set up the AV2 connection to DECODER
    The only problem is if the sky+ is on then whatever the DVDR is tuned to BBC1 etc it will only play and record what is on sky+ at that time
    If I turn it to normal this does not happen
    So what should I have it set to Normal which seems to work best or is there a reason I should have it set to DECODER?
    Bob
  2. bobbles
    bobbles
    well judging by the replies the following link may be useful
    Panny E30 Hints and Tips
    Very happy with the player
    Bit disappointed with the menus on a recorded -R disk
    Just a list, no pictures
    Bit poor IMO
  3. thfccambs
    thfccambs
    Jul 17, 2002
    19,149
    White Hart Lane
    +5,257
    Bobbles there was me thinking you was going to go for the philips dvd recorder.
  4. bobbles
    bobbles
    no didn't you read my other thread
    went for the Panny in the end
    the VBR and the worrying reliability of the Philips swung it Pannys way
    I just replied to your other thread in dvd talk
  5. bobbles
    bobbles
    Now Big Les has gone and they have said they are not interested in Ricketts
    Nor should they be he is crap
    I think there could be truth in that whisper
  6. thfccambs
    thfccambs
    Jul 17, 2002
    19,149
    White Hart Lane
    +5,257
    I also heard yesterday from 2 other people about fowler,so will have to wait & see.
    would be very nice.:D
  7. jryoung
    jryoung
    Aug 8, 2000
    35
    Guildford,Surrey,UK
    Reading that tip - does that mean that the E30 cannot respond to any timer recordings via RGB input on AV2 :confused: (eg from a (non-panasonic!) DTT set top box)? How about via S-Video in?
    Currently, I am very happy with my new E30. I have a Panasonic 32DT2 DTT tv, which works extremely well with the E30 due to the QLink function. I just set the TV EPG based timer, and the E30 records (a composite signal) from the DTT output via the TVs AV1. Playback is via S-Video on AV1.
    However, I was considering getting a separate Freeview tuner to feed the E30, on the basis that one with a timer could drive the E30 in a similar way to the TV, but with RGB as the source. Has anyone done this?
  8. bobbles
    bobbles
    yes it can
    However the Panny can not auto switch the sky box
    but you can set it up to autorecord when it detects a prog on auto view
    however, you can not use this with sky+ as I don't think sky+ has autoview just reminders or record
  9. Bogside
    Bogside
    Sep 20, 2002
    3,038
    Stockport (ex Derry)
    +383
    I've got the Panny E30 but I'm on NTL cable. I don't think this is anywhere near as advanced as Sky (never mind Sky + !) but reminders can be set and the channel switch is automatic. Does anyone know if the Panny can do this for me in any way.
    I was thinking it might be possible through videoplus? For example, if I set a videoplus programme for Sky One I'm sure the Panny will ask me what channel it's corresponds to on AV1. So then next time I set videoplus for Sky One will the Panny automatically change the channel on the STB?
    Or does anyone have alternative ideas?
    PS I haven't thought of trying this yet but I might give it a go tonight.
  10. bobbles
    bobbles
    It might be
    you have to set the AV2 connection
    to ext 1 or something like that
    try it
  11. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    I'm puzzled why you would need to use timer recording on the E30 when you have Sky+ :confused:
    Everything I want on either DVD-R or DVD-RAM is first recorded onto Sky+, I haven't even set the E30 up so it can timer record, with Sky+ fed into AV2 via scart I have all my needs met.
  12. bobbles
    bobbles
    i suppose you might if you were out and wanted to record two things at once
    come on dual record!
    I don't think you can do the timer record autoview thing anyway as I don't think sky+ has this option
    just got some ram for less than £3 work perfectly top stuff
    what do you use ram for? i can only imagine using it if sky+ gets full or for editing before burning onto -R
    when i get a writer that is
  13. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    I use the RAM disks for music videos, the handy editing features come in handy. But as I got 4 for free I'm not going to buy anymore as I'll never fill all those due to my picky taste.
  14. bobbles
    bobbles
    well i got 2 free and bought another 8 before I got the player
    now i have them I am left wondering what to use them for
    I can not believe the high st prices for disks in HMV a single -R was 9.99
    they are taking the p
    I can imagine a time though when -RAM are so cheap I will only use those for archiving
  15. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Assuming my HS2 works the same as the E30, if you set it to normal in this situation it will record from the channel selected. However you can't then view the digibox on the tv via the rgb loop through when the machine is timer recording even if it is recording sky. This seems to be associated with rgb output from the digibox overiding the source in the recorder. You could loop the secondary scart direct to the tv or via a video and watch non rgb signal on the tv.
    I have, though, given up with using the RGB in straight to the recorder as above, as in approx 1 in 4 or 5 autoview from the personal planner recording attempts the digibox drops the rgb signal and sends ordinary video instead, even though set to send rgb. This results in a recording of sound only and a blank screen. I am informed that this is a relatively common problem.
    The problem resolves when the box is rebooted, and can't be detected from the tv as the rgb scart autoselects whatever signal arrives. Unfortunately the recorder does not and this has caused me some hassle. As recording the program I want to see is more important than ultimate quality, I now have the second scart connected to the HS2 and the recorder connnected to a non rgb scarton the tv and everything set to video. THe digibox is set to rgb and goes to the tv rgb scart.
    With this set-up the recording is reliable and you have to now set the input as decoder, as when set to normal, I have found that say when dubbing a 2 hour dvd you can only view the onscreen info from the recorder on both the recorder input to the tv and it also feeds back through the digibox to that input as well.
  16. bobbles
    bobbles
    yes I have put the VCR scart on sky+ to a secondary scart on my TV, incase i am recording on sky+ and recording on the dvdr
    you never know!
    I am know actually using my switch box to RGB IN on the DVDR
    3 sources
    Normal DVD player
    X-BOX
    SKY+ TV Scart
    Sky+ is also connected to AV2 on TV
    Normal DVD is also connected to TV using component cables
    The optical set up was trickier with 4 sources and 2 inputs
    but surely you can view what the DVDR is recording i.e sky
    I will have a go later
    Have you got sky+ Ken?
    If so how are you getting it to autoview?
  17. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    It definately does not allow you to view the source through the recorder when set to normal, and a timer recording is happening, with the unit otherwise off. With it on you can view the recording as it happens or play it back from the beginning or another recording already on the hard drive or -ram disc, not though I understand when recording straight to -r?
    Set to decoder and you can always see the source but can't select anything else to record. This only happens when the input is set to rgb. There must be a signal on the rgb feed commanding the recorder to only see the digibox
    Change the input to video, and set as decoder and everything works fine.
    I haven't got sky+, whats the point with a hs2 which does everything I want without the extra subscription, which is how I justified buying it in the first place. (Except for the second tuner of course, but this is rarely a problem)
    I don't believe that sky+ allows all the ads, intros and over-run to be removed, before copying to dvd-r either?
  18. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    You can customize the way Sky+ records, by default it's set to start recording a few mins before the proggy and end a few mins after it finishes. You can change the start and end times but you of course risk missing a bit of the proggy.
  19. kerraig
    kerraig
    Can you plug a PC into this recorder and burn DVD-R's that way?
  20. yonderblue
    yonderblue
    Dec 18, 2001
    302
    Scotland
    +12
    Nope, Not unless you are talking about streaming some video or SVideo/Composite output via the PC Graphics Card or TV Card from your PC to the DMR-E30. About the only way you could is if you had a the Panasonic DMR-HS2 and if your PC had a Firewire connection and plug this into DMR-HS2, but I believe the DMR-HS2 is very fussy about what you plug into the Firewire input of the DMR-HS2.
