Panny DVD Recorder in Canada
Discussion in 'Blu-ray & DVD Players & Recorders' started by Raymate, Sep 3, 2005.
  1. Raymate
    Raymate
    Sep 3, 2005
    19
    At the moment I have a Panasonic E65 that is multi-region here in the UK. Next year I shall be moving out to Toronto Canada.
    Now my current machine is not multi-voltage and the tuner will not work I assume. So I dont think it's worth taking with me. Because I assume it will only be good for playback.
    So I want to get another Panasonic deck in Canada.
    My questions are:
    1. Do any stores in Canada (Toronto) sell Panny decks that have been changed to multi region, as I would like to take some of my PAL discs with me.
    2. Can anyone recomend any stores.
    3. Would it be easy to make a machine multi region in Canada myself.
    If any one can help with this, that would be great.
    It seems no TV in Canada can handle a PAL signal, unlike our TV that do both. So I'm not sure how I would view PAL DVD (home made or puchased ones)
    R :)
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    Making a Canadian Panasonic region-free wouldn't help you, as they can't play PAL discs (at least the EH50 can't, I checked that manual for the Canadian model; I expect the other models are the same. The issue is your last point, that most NTSC DVD players won't accept a PAL disc, and most NTSC TVs won't accept a PAL signal.
    You are right that your UK recorder won't do you much good there.
    I suggest getting a Canadian DVD NTSC recorder, and not worry about region-free or PAL for that. Then separatly buy a NTSC DVD player which will handle PAL discs and convert them for play on NTSC TV. These are in a minority, but they do exist - here is one
    http://regioncodefreedvd.com/jvc312.html
    Of the "name brands", JVC seems to have a number which play PAL discs. My sister in the USA has 4 DVD players, when I sent her a PAL disc the only one which would play it was a JVC (not sure which model). A bunch of no-name Chinese brands also do this. Looks like the Pioneer 270S also does PAL to NTSC conversion. You could take a PAL region-2 disc to a shop and try some out.
    The link I sent was a US site, not Canadian, but both US and Canada are NTSC.
    Mark
  3. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    Or, go for a JVC recorder, something like this (Canadian Model)
    http://www.jvc.ca/en/consumer/product-detail.asp?model=DR-MH30S
    It has "PAL Playback on NTSC TV (DVD)"
    Out of the box it probably isn't region free, but I would think you could find a supplier for a region free one in Canada. Otherwise you'd need to import one from the US.
    Mark
