Panny DMREX77 or Sony ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by atr1981, Sep 15, 2007.
  1. atr1981
    atr1981
    Jan 29, 2007
    1,781
    Ipswich, Suffolk
    +73
    Hi Guys,
    Currently got a u/s Panny DMREZ25 that I want to change.
    I have thought about the DMREX77 but wondered if there was a player of the same sort of spec to consider ?
    Perhaps a Sony ?
    Alex.
  2. MuksC
    MuksC
    Aug 18, 2007
    885
    43
    +133
    I have the Panasonic and it's fantastic.
    a similar spec'd machine is the Sony RDRHXD870B-CEK (B indicated black, S indicates silver unit): Click
    compared to the Panasonic DMR-EX77-EB-K (K = black, S = silver): Click
    (don't necessarily buy from there, just giving you the spec from someone who sells both recorders. DigiUK.com do the EX77 in black for £230, or the next model up, the EX87 which has a 250GB hdd, for £296. you can probably find them both cheaper at other online retailers though, i saw the EX87 for £288.89 the other day. The silver versions seems to be more expensive than the black ones at most places though, don't know why.)
    I haven't read the threads about the Sony, but if you search for "Sony 870" you'll probably find lots of threads in which people tell you their likes/dislikes and any problems with the machine.
    same for the Panasonic, search for "Panasonic EX77" and you'll find lots of threads.
    I've had the Panasonic for 2 days and i haven't had any problems with it and think it's brilliant (see my opinions in this thread:Click), so i'd recommend it to you, but you'd need to read the opinions of Sony owners too, to get a fair opinion on which one you'd like to buy.
  3. atr1981
    atr1981
    Jan 29, 2007
    1,781
    Ipswich, Suffolk
    +73
    Thank you for your in depth reply.
    Ours is going to be away for 6 weeks getting repaired so think i'm going to go for the new model once it is returned. Don't want to be using soiled goods. :rolleyes:
