panny DMRES10 or sammy HD850?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Hiran, Jul 5, 2005.
  1. Hiran
    Hiran
    Hoya. I am new to this forum site. I have recently purchased a Panasonic Th42PV500 (ebay winner!!) and wanted to hook it up to a dvd player which shall give the best pic quality on the panny screen. The plasma came with a free panny dvd recorder (DMRES10) but it doesnt have a HMDI output to go with the screen. I have read all the reviews about the dvd recorder and suggests the player is excellent. But how good is the pic quality? I shall not be using it to do too many recording so i rather have a player that is dedicated to picture quality only. I have been reading the forum and magazines and the Samsung HD945 comes across to a good budget player with HDMI (replaced by the HD 850). What I would really appreciate knowing is from any panasonic DMRES users on how good the pic is compared to a stand alone dvd player? What dvd should I purchase to go with my PV500. I dont want to spend above £200 (wanna wait for HD DVD to come out!!). I want the best pic quality and think that HDMI might be the way to go. Please advice. If you recommend another dvd player then please suggest. I have been also considering the Panny S75 - but have been put off by the xtra twiking required to get the perfect pic. So shall i stick it out with the recorder EMRES10 or go for the Samsung S850 or any other? I will really appreciate any advice given. Many thanks in advance
  2. pwood
    pwood
    Dec 6, 2003
    2,569
    Central Scotland
    +163
    If you need to record anything then a DVD recorder is the bear minimum as a VCR will look terrible on a big screen also bear in mind the Es10 outputs progressive scan via component so will be a lot better than you might expect.
    Samsung HDMI palyer seems like the best option at present and certainly for under £200 there is no competiton at present apart from Panasonic machine which has been discounted heavily.
  3. Hiran
    Hiran
    thanks for your kind reply. You have swing my decision to buy the Panny DMRES10 recorder for the moment, then invest in HDD dvd player when theuy come out.
