Panny Dmr-es10eb - How To Record Freeview?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Wing Co, Aug 7, 2005.
  1. Wing Co
    Wing Co
    Aug 7, 2005
    95
    +9
    I have the Panny TH-42PV500B and DMR-ES10EB and all is well apart from I cannot record Freeview. Set up using scart and Q-Link and downloaded TV stations to recorder, but the recorder has only take channels 1-5 and not the Freeview ones. Tried direct recording, but just records a blank screen. I'm not particulary smart with all the AV language so if someone can help please spell it out carefully.
  2. Goooner
    Goooner
    Jul 23, 2005
    35,536
    2
    Milton Keynes
    +13,956
    You need to go into the setup menu on the PV500 and set AV2 or AV4 (whichever you've got your Q-Link going to) and set it to DVB out.
    Then Freeview should be recordable on AV1 in the ES10 or via direct record or the Freeview timer on the PV500. Videoplus won't work unfortunately.
  3. Wing Co
    Wing Co
    Aug 7, 2005
    95
    +9
    Many thanks for your help recording fine. It's a bit of apain that you cannot timer record the programmes though.
  4. Goooner
    Goooner
    Jul 23, 2005
    35,536
    2
    Milton Keynes
    +13,956
    Agreed, videoplus would have been nice. Using the guide on the TV seems to work just as well.
  5. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    Gooner where is that menu option to set that Av2 etc?
    Also how do you have you es10 / panny / sky+ connected up?
    CK
  6. Goooner
    Goooner
    Jul 23, 2005
    35,536
    2
    Milton Keynes
    +13,956
    You want "menu" on the remote, then setup menu bottom of the three choices, top choice is then Q-Link, which can be changed between AV2/AV4. Next line down will be AV2 (or 4) Out, on that line you get 6 choices, second one along is DVB.
    I've got RGB scart from Sky+ to Panny scart 1, then the Q-link scart from the ES10 into scart 2 on the Panny.
  7. ColdKilla
    ColdKilla
    Jun 21, 2005
    726
    +19
    With no scart from sky+ to the es10?
    How do you record sky+ programs then?
    CK
  8. Goooner
    Goooner
    Jul 23, 2005
    35,536
    2
    Milton Keynes
    +13,956
    Don't really bother archiving stuff from Sky to be honest, so I just watch it and delete it.
