Panny DMR-E95 Hard Drive
Discussion in 'Blu-ray & DVD Players & Recorders' started by milanlad, Feb 18, 2005.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Is it possible to record onto the internal hard drive via a source connected to the Scart inputs?
    If so, can you record in RGB, and can you record in the different resolutions SP, LP, EP etc.??
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,200
    Argyll
    +2,257
    Yes.
    Yes.
    Yes. The different recording modes alter the bitrate - the resolution will either be full or half resolution. XP and SP are both full resolution. FR mode upto approx. 3hrs will also be full resolution. LP, EP and FR 3hrs+ are half resolution.
    Refer to the 'Which DVD Recorder?' link in my signature for answers to the basic FAQs.
  3. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Is it possible to transfer or copy from a DVD film onto the hard drive of the E95?
    Basically, I want to keep all my movies onto the hard drive of the E95, to playback anytime I like without inserting different DVDs.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,200
    Argyll
    +2,257
    Only not copy protected content, i.e. your own recordings and not a commercially purchased DVD-Video. No DVD recorder will do that.
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    And you can't copy from the drive in the recorder, you would have to have the non copy protected dvd play in another machine connected to the recorder.
  6. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Can the E95 output on AV1 (as RGB) and output on the Component Video terminals at the same time?
  7. Tellyfiend
    Tellyfiend
    Jan 21, 2005
    225
    +13
    No it can't.
    It can output S-Video and Component or Composite and Component though.
  8. sdh500
    sdh500
    Actually, according to the manual (p. 37) you can indeed copy a non-protected movie from the DVD drive to the hard drive on the E95 - they added this facility just in case you need to re-edit finalized content on a DVD-R. So no external machine is necessary. :smashin:
  9. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Does anyone know what make of hard drive the E95 uses?
  10. sdh500
    sdh500
    It's a Panasonic AVHDD (Audio Visual Hard Disk Drive)
  11. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    A Matsuwatta ? :rotfl:
  12. sdh500
    sdh500
    Don't forget that the HDD is only meant to be a temporary storage device. If anything goes wrong with it then you've lost all your films. Better to save them to disc.
