Panny DMR E85 Regions?
Discussion in 'Blu-ray & DVD Players & Recorders' started by meridian808, Jul 20, 2004.
  1. meridian808
    meridian808
    Jun 8, 2004
    40
    +3
    I have set this up with a component connection with superb results.
    It is a region 2 player, however will this play region 2 jap disks & 0 region disks? or just region 2 europe.
    I believe there is no hack as such.
    THX
  2. anephric
    anephric
    Mar 23, 2002
    1,048
    Derby
    +147
    Region 2 is Region 2 isn't it? There are no subdivisions (like 2.1) as far as I know. Region 0 should play on anything.
    I think you can use a "chipped" remote to enable multiregion playback on your E85 (they go for @£30). I got mine multiregion out the box as I couldn't be bothered with R2 only.
    regards,
    anephric
