Panny DMR E-85
Discussion in 'Blu-ray & DVD Players & Recorders' started by andykaz, Jan 6, 2005.
  1. andykaz
    andykaz
    Jan 4, 2005
    43
    Does this DVD recorder possess the feature that the JVC MH20 etc does (Live View IIRC) where it will automatically buffer a designated amount of time on to the HDD. I.e you do not have to set the DVDR to record, and can therefore record programmed retrospectively? Because this sounds like a really nice feature.
  2. judy
    judy
    "record programmed retrospectively"
    please clarify this. i have the manual to hand but dont understand your question. it will calculate the best fit of a programm on to hdd, and i'll look to see if it is recording on dvd and runs out will it swithch to hdd. is that what you mean
    judy
  3. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,901
    Reading
    +291
    No it does not have a live buffer. In fact the HDD goes to sleep after 30 mins of no operations.
  4. andykaz
    andykaz
    Jan 4, 2005
    43
    Thanks for your reply.
    Thats dissapointing, do any other DVDHDDs other than the JVC range offer this feature?
  5. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,901
    Reading
    +291
    Sorry I don't know, maybe others will do.
    My TiVo has a live buffer but to be honest I don't find it particularly useful as it only records one channel at a time so what you might want to record may not be being buffered because it’s on a channel that is not being monitored.
  6. andykaz
    andykaz
    Jan 4, 2005
    43
    I see what your saying. As i use Cable though, i can see situations occuring where i get in to a film, doccumentry etc, and wish that i had set it to record.
  7. okcomputer331
    okcomputer331
    i will be recording from Sky+ to the panny E85 (if my pannyE85 arrives tomorrow :clap: ) so I guess sky + will do all my "recording retropectively"...
