Panny DMR-55 & DVD-RAM
Discussion in 'Blu-ray & DVD Players & Recorders' started by Welshman, Sep 21, 2004.
  1. Welshman
    Welshman
    Does anyone know a supplier that has the most reasonablly priced DVD-RAM media adn does the DMR-e55 take the caddy-type DVDRAM?
    Thanks in advance
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,210
    Argyll
    +2,265
    I tend to stick with Panasonic brand DVD-RAMs - available at a good price from the Panasonic Eshop (find the link on www.panasonic.co.uk ). The E55, like any Panasonic or Toshiba DVD-RAM recorder, will take caddied or uncaddied media.
  3. Welshman
    Welshman
    Thanks Unfortunatley Panasonic site out of stock of 9.4 gbs :mad:
  4. apreading
    apreading
    Jun 28, 2004
    283
    +15
    Get the 4.7s in 5 packs.
    the 9.4 is a flipper so you can only record 4.7 on each side, and costs much more than 2 individual 4.7s. Therefore a little pointless...
    7dayshop.com actually undercut panasonic eshop by a pound on the 5 packs of 4.7s and postage is only a quid I think so also worth considering.
    If you want cheaper SVP (blankdiscshop.com) have some other brands which I am just trying to see how they are.
    I wouldnt bother with caddys to be honest - the coatings are supposed to be much better these days and caddy is not too important anymore.
  5. bimbo1973
    bimbo1973
    The panasonic 4.7's are £13.50 for 10 at Costco
