A few days ago I lost the DVD-S EPG listing on my Panasonic TX-L42D25L (Ireland model). All the channels show up in the order I had them set in the EPG, which I can access when I scroll through the channels using the channel up/down button on the remote. I have tried the update channel list in the settings menu - no good. I have also tried the Auto Setup but this stops after a second or two. Once since the problem started I got the New channels found message but after the scan the EPG still drew a blank. The tuner seems to be fine, as I can scan a frequency & the channels appear "found". I am now unable to set the timer since there are no channels in the EPG to program the timer - "no listings found".
Any suggestions besides a factory reset, I don't want to loose what I have should nothing reappear after the reset.
Strangely the DVB-T side of things, functions are fine, full EPG listings & timer functionality.
Please help
Please help
