Panny Component Boards
ppp65
Can someone in the know tell me if there is a difference in the component input on the:
Compoent Board TY-42TM6AB
BNC Terminal Board TY-42TM6YB
Is it worth paying the extra for the YB if I'm only going to use the component input or am I missing the point?! The 8 series panels already have the composite/s-video board supplied so I wouldn't need any more of these connections.
UKseless1
Are you aware that the VGA input on the 8 series panels can accept component? Not sure of your requirements but if you don't want to connect up a PC then you could avoid the cost of the component board as the panels come with the VGA input.
theo cupier
If you don't need extra composite or s-VHS connectors, get the component only one.
Bear in mind that if you are planning to use the composite connector that comes with the standard board, it's BNC, not the RCA type which you may be used to.
theo cupier
True enough but depending on how you switch from component to VGA, getting the component board may be cheaper.
UKseless1
I use a component to VGA cable - not aware that they are too expensive (approx. £25 per metre for a reasonable one) and given that you have to buy the cable anyway....
Having said that I switch everything through an amp first with just the one component to VGA cable going to the screen.
