Panny code keeps getting lost on Sky+
Discussion in 'Sky Digital TV Forum' started by sunil1234, Jul 27, 2005.
  1. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    48
    +25
    Have a Panny 42PV500 with Pace SKy+ box.
    Since the Panny was installed on saturday, i have set the code for the remote to work the telly (using code 0051)
    Problem is that the code seems to have to be reprogrammed every few hours or a day as it keeps stopping operating the tv controls (volume & standby)
    First time i put the code in when programming the tv test of putting it into stand by works so i press select to save it and it confirms with two flashes.
    Perhaps a different code is needed by Sky cant tell me otherwise?
    Any thoughts/ help much appreciated
  2. JayCee
    JayCee
    Jan 20, 2004
    19,789
    Lanarkshire
    +1,883
    I take it you realise you have to press the "Sky" button to operate Sky and then the "Tv" button to operate the TV standby.......if you are using the correct code it should also change the Tv channels using the "CH + & - " buttons after pressing the "Tv" button.
  3. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    48
    +25
    yep mate, it all works for a few hours/ a day then - it just doesnt. Have to reprogram again!
    ANy thoughts?
    Ta
    S
  4. JayCee
    JayCee
    Jan 20, 2004
    19,789
    Lanarkshire
    +1,883
    As long as the Panasonics own remote isn't giving you similar problems (and if it did the fault must lie with the Tv) it looks as though the Sky remote needs replaced.
  5. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    48
    +25
    Nope the Panny remote is fine. I have just used a new code instead of 0051, it is 678 (i thinK) which i found using a search so i will see how long that lasts and if not, phone sky+ for a replacement remote. Put the new code in last night and it seems to be ok so far.
    S
  6. mart280
    mart280
    May 30, 2005
    67
    I had exactly the same with my panny tv, try putting some batteries in the sky plus remote that have been used a bit, it worked for me.
  7. woodss
    woodss
  8. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    48
    +25
    Cheers it lost the 678 code today so i have put it some other batteries and see if the helps!
    S
  9. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +309
    Loose battery clips.
  10. pmc
    pmc
    Oct 18, 2004
    1,411
    +109
    I'm getting exactly the same thing with normal Sky and a Philips TV. I program it and it works fine, then after a few hours it 'forgets'. It's a brand new remote with brand new batteries, only bought it on Saturday. Weird.
  11. cR4cKF0x 5TevE
    cR4cKF0x 5TevE
    Sep 7, 2004
    2,012
    St Merryn
    +280
    I had exactly the same problem.
    Sky technical support were very good (I know !!) and talked me through a couple of tests/tricks before deciding either the battery terminals in the remote were damaged/faulty, or the memory of the remote itself was faulty (apparently a known problem/fault on v4 Sky+ remotes).
    They agreed to replace the remote and the new one turned up within 3 days!
    I now have a shiny new version 6 Sky+ remote and it works perfectly, even driving my Marantz receiver with the punchthrough codes taken off the hummer web site.
