Quantcast
Panny bdt110 vs a ps3 (advice required)
jaspain
Guys
I am some advice. I have a Panasonic pt460 surround which has issues transferring dts signals via optical. When I select the below option on PS3 it decodes the signal and I get 5:1 surround:
- Bitstream Mix, is for systems that don't normally accept DTS over optical, like Panasonic's systems.
It passes everything out as a DD5.1 soundtrack.
However on my new Panasonic 3d blu ray bdt110 player I can't get the settings to replicate the ps3 and not all the sound is coming out, I even have issues transferring a 5:1 Dolby off a DVD, I have to change the amplifier to pro logic movie which I haven't had to do previously on PS3
Any ideas?
mentm
If your surround sound is not dts compatible the best you will get from your panny 110 is stereo sound with dts discs.
mentm
I don't think it does, though the ps3 has more processing power than a bluray player so most things are possible.
