Panny and PS2
Discussion in 'Plasma TVs Forum' started by toonarmy, Jun 21, 2003.
  1. toonarmy
    toonarmy
    May 23, 2002
    226
    Dumfries
    +6
    I am in the process of buying a Playstation 2 for my son this is to be connected to the Scart on his portable TV.
    On occasion I may be tempted to hook it up to my Panasonic Plasma (TH 42PWD4BX).
    I am already using the VGA input for Sky and the component for DVD, leaving me S Video and composite.
    What cables will I need to hook it up to the Portable and the Plasma to give me the best results.
    Toonarmy
  2. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    Why don't you 'cascade' or 'daisy-chain' the PS2 through the Sky box to the VGA converter.....I do this with my PS2, through the Pace Telewest box.
    I used a Blaze RGB Scart cable for PS2, the picture is STUNNING I tell you!
  3. jont
    jont
    Apr 8, 2002
    4,268
    near Aylesbury
    +553
    I used to have my ps2 through my didgibox in rgb and worked well ...
    I f you use ps2>svideo would be better than composite ...
    but on series 4 panny you can't use svideo and composite at the same time ...
    in case you were wanting to hook up a vcr or digicam as well ...
    rgds
    Jon
  4. toonarmy
    toonarmy
    May 23, 2002
    226
    Dumfries
    +6
    Thanks for the info.
    Can anyone recommend any good sites for PS2 cables etc
    Toonarmy
  5. jont
    jont
    Apr 8, 2002
    4,268
    near Aylesbury
    +553
    got my old cables from www.lik-sang.com in hong kong ...
    dirt cheap, low p&p and good delivery times ;-)
    Jon
  6. Nick Laslett
    Nick Laslett
    Oct 9, 2002
  7. grobschnitt
    grobschnitt
    Jul 5, 2002
    19
    Lincs
    Geting a PS2 this Christmas - I have the Panny TH42PWD4 and sky box is connected via JSTech VGA, DVD direct as is video. I have a Yam E800 and try to connect my sons PS1 via the AV amp and plugging a S-video from this to the Plasma. This didnt seem to work. Direct route to s-vid input does but you loose the video to the s-vid default.
    Interested in the sky box connection suggested. ? how do you do this there doesnt seem to be any conections available and how do you swittch from tv to PS? Anyone with the Yam AV sorted this out?(sound and vision)
    :confused:
  8. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Does PS-1 support Svideo? not sure.
    Best way might be to use the component port on the panny for PS-2. Get the coponent cable from the playstation uk shop website.
