Quantcast
Panny AE500, PS2 doesnt fill the whole screen
KrisBennett
Last night I hooked up my PS2 to my Panasonic AE500.
The PS2 is connected to my Denon 3803 via a component cable
The Denon 3803 is connected to the PJ via a component cable
Everything works fine except that the PS2 doesn't fill the whole of my 69" screen.
example (not to scale) :
My PS2 is set to widescreen, am I missing something.....
any ideas??
thfccambs
Great question,my ae200 does the same on PS2.:confused:
Gillykid
Set your PS2 to Full Screen - that seems to work for me (AE500) - dunno if you miss any action tho....
G a f f e r
same happened to my ps2 on the ae500.
In fact, similar thing hsappens to my Gamecube on the AE500.
I only lose about 3 inches from either side of a 6 foot screen so I don't really worry about it.....
.....try setting the aspect to "Justify" :)
Similar threads
