it can be 5000 hr at most in low lamp mode
2000hrs in high lamp mode
if you use the ai you have to run in high lamp mode so life will only be up to 2000 hrs
lamp life is not guaranteed as it can vary in accordance with how often you run the unit and how often you switch the unit off/on(the more power cycles you do the shorter the lamp life)
