Panny AE300 vs NEC VT540
Discussion in 'Projectors, Screens & Video Processors' started by coldfact, Jan 4, 2004.
  1. coldfact
    coldfact
    Guys, any pointers on what I might miss if I sell my 1000 Lumens XGA NEC VT540 and go for the Panny AE400? Used for DVD, DivX, and Digital TV.
    thanks, I'm thinking things like brightness and resolution, but any other info would be great.
    thanks
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    What is it about the Nec that makes you want to change it for an AE300 ? An answer to that question might enable Ae300 owners or others to give you an opinion on whether you'll get whatever it is you're looking for...........
    Sean G.
  3. Kramer
    Kramer
    Yes, a picture for one thing. There isn't an AE400 :D
    As Sean says, just what exactly are you asking about?
    You received pretty good replies here which are still applicable whether you're looking at a Z2, AE300 or Epson etc.
    Find a helpful dealer, get out & see a few LCDs.
    Best of luck.
    :smoke:
