Panny AE100E User Manual?
Discussion in 'Projectors, Screens & Video Processors' started by pompeysteve, Dec 23, 2003.
  1. pompeysteve
    pompeysteve
    Aug 22, 2002
    624
    46
    Portsmouth, England
    +117
    I'm trying to find a PDF user manual for the AE100E. The link on the panasonic.co.uk is broken....any know where I can find one? Or do you have one you could email to me?
    Failing that, does anybody know what battery the remote control takes?...
    Thanks,
    Steve
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Steve,
    I have one on my home machine - I'll post a link when I get home, if no one answers before then.
    Sean G.
  3. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Ooops..... found it - you can DL the AE100 docs from this site
    All the best,
    Sean G.
  4. pompeysteve
    pompeysteve
    Aug 22, 2002
    624
    46
    Portsmouth, England
    +117
    Thanks for that !
    Turned on my Proj last night and the green power light flashed for about 10 seconds then it went amber then flashed green...
    The lamp light lit up but after pushing a button all seemed ok. I need a new battery as I can't get the OSD to check the lamp hours out!
    Perfect timing for the lamp to be on its way out don't ya think! :(
