Panny AE100 stays in standby???
Discussion in 'Projectors, Screens & Video Processors' started by Swinnydon, Sep 8, 2003.
  1. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    When the unit is initiall powered on, I can get it into "on" mode. It stays on for about 10 seconds before going into standby. I cannot switch the unti back on without actually toggling the power at the back of the unit or removing then replacing the power completely. :confused:
    Is this a known problem? What's the cure?
    Chris
  2. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    When it goes into standby does the Red LED flash?
    If it does you might want to do a search for 'Red LED of death' :(
    -- Jon
  3. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    Nope, the red light stays "solid" in that it doesn't flash at all. Any other ideas? I'll do a search for the red light of death anyway to see if that throws out any other ideas
